sna
Posts: 721 Joined: Tue May 05, 2020 8:18 am
Excel Ver: Excel 365
by sna » Fri Sep 25, 2020 6:00 pm
Hi
Dear
I need your help with copy and paste from folder.I test code is ok but if I copy this file is not working.
I attached working fine and source file
Best Regards,
1. Disbursement Time Analysis 2019-2020.xlsm
(39.13 KiB) Downloaded 22 times
22-09-2020.xlsx
(22.99 KiB) Downloaded 16 times
by snasui » Fri Sep 25, 2020 7:38 pm
Could you please capture the error and attach here?
sna
by sna » Fri Sep 25, 2020 10:17 pm
Hi Dear,
It doesn't show any error but it doesn't copy the desired output.
I don't know why .I step through the code but nothing occur.
What's wrong with?
Best Regards,
by snasui » Sat Sep 26, 2020 7:51 am
Change
MyFile = Path & "*.xls*" to
MyFile = Dir(Path & "*.xls*") and if you want to loop other file in this path, add
MyFile = Dir() after
Application.DisplayAlerts = True statement.
sna
by sna » Sat Sep 26, 2020 3:05 pm
Thank you
sna
by sna » Mon Sep 28, 2020 2:46 pm
I try as suggested but no luck.
It has problem copy and paste .it open file but not copy n paste
sna
by sna » Mon Sep 28, 2020 5:32 pm
It sometimes can't open file.what is wrong?
excel file is always extension .xlsx
by snasui » Tue Sep 29, 2020 10:08 pm
sna wrote: Mon Sep 28, 2020 5:32 pm
It should be '.xlsm'.
