sumifs not worked
Posted: Tue Jul 23, 2024 8:34 am
by sna
hi there,
I have a problem with sumifs ,it is not working .it is wird
i attach a template
thanks
Re: sumifs not worked
Posted: Tue Jul 23, 2024 3:49 pm
After checking the result in cell D9, I found that your data did not meet the conditions in the SUMIFS function, particularly at the part
'LN Active-Data'!$AP$5:$AP$163, C9
. After filtering your data, only 2 records were found.
Be aware that you can utilize a filter to verify your results when employing SUMIFS.
Posted: Tue Jul 23, 2024 4:11 pm
by sna
Thanks,I filter but not check this column
