vba_rearrange_data
Posted: Mon Dec 02, 2024 9:30 am
Hi Dear!
I need your hand to correct data arranging in a new sheet.I try but it's no luck
Please help fix it to get outputs like the hightlighted sheet.
Noted:you can change variable to whatever it is easier to read as well.
thank you in advance
Sub FormatLoanData()
Dim ws As Worksheet
Dim outputWs As Worksheet
Dim lastRow As Long
Dim currentRow As Long
Dim outputRow As Long
Dim currentOfficer As String
' Set the worksheets
Set ws = ThisWorkbook.Sheets("RawData") ' Change to your actual data sheet name
Set outputWs = ThisWorkbook.Sheets.Add
outputWs.Name = "Output"
outputRow = 2 ' Start output from the second row
lastRow = ws.Cells(ws.Rows.Count, 1).End(xlUp).Row ' Get last row with data
For currentRow = 2 To lastRow ' Assuming first row is header
' Check for Credit Officer header
If InStr(ws.Cells(currentRow, 1), "Credit Officer:") > 0 Then
currentOfficer = ws.Cells(currentRow, 1).Value ' Store current officer
' Skipping the credit officer line
ElseIf ws.Cells(currentRow, 1).Value <> "" Then
' Copy Data to formatted worksheet
outputWs.Cells(outputRow, 1).Value = ws.Cells(currentRow, 1).Value
outputWs.Cells(outputRow, 2).Value = ws.Cells(currentRow, 2).Value
outputWs.Cells(outputRow, 3).Value = ws.Cells(currentRow, 3).Value
outputWs.Cells(outputRow, 4).Value = ws.Cells(currentRow, 4).Value
outputRow = outputRow + 1 ' Increment output row counter
Next currentRow
