index function
Posted: Mon May 24, 2021 4:15 pm
by sna
Hi Dear
I need to lookup value and return value from adjacent cell but only unique
Note: need only formula
I attached a template
Best Wishes,
Re: index function
Posted: Mon May 24, 2021 4:45 pm
by norkaz
It could be possible and properly to use the formulas that place E2:G5 as attached.
Try this, if you need another way.
I2
=IFERROR(INDEX($A$1:$A$16,AGGREGATE(15,6,ROW($A$1:$A$16)/($A$1:$A$16<>""),ROW(A1))),"")
Copy down.
J2
=IFERROR(INDEX($B$1:$B$16,AGGREGATE(15,6,ROW($B$1:$B$16)/(LOOKUP(ROW($A$1:$A$16),ROW($A$1:$A$16)/($A$1:$A$16<>""))=MATCH($I2,$A$1:$A$16,0)/($B$1:$B$16<>"")),COLUMNS($J$2:J2))),"")
Copy down and to the right hand side.
Norkaz
Re: index function
Posted: Mon May 24, 2021 5:12 pm
by sna
Hi Norkaz,
In J2 not what I need .
In should return unique subject by student name like below
Sharmin English Math
Mahi English
Mahiha Math English Physique
Arifa Math English French
Best Wishes
Re: index function
Posted: Mon May 24, 2021 5:21 pm
by norkaz
Hi Guy,
Please give me any info for more clarify about your points.
If my understand is correct, refer to your first attached you don't need the formulas E2:G5 but you need only "ONE FORMULA" that place D2 and then copy to the right hand side and down , then the results would be as appeared as attached, right?
Norkaz
Re: index function
Posted: Mon May 24, 2021 6:31 pm
by norkaz
D2
=IFERROR(INDEX(INDEX($A$1:$B$16,0,MIN(COLUMNS($D$2:D2),2)),IF(AGGREGATE(15,6,ROW($A$1:$A$16)/($A$1:$A$16<>""),ROW(A1))+COLUMNS($D$1:D1)-1>IFERROR(AGGREGATE(15,6,ROW($A$1:$A$16)/($A$1:$A$16<>""),ROW(D2))-1,AGGREGATE(14,6,ROW($A$1:$A$16)/($B$1:$B$16<>""),1)),"",AGGREGATE(15,6,ROW($A$1:$A$16)/($A$1:$A$16<>""),ROW(D1))+COLUMNS($D$2:D2)-1)),"")&""
Copy to right hand side and down.
Norkaz
Re: index function
Posted: Mon May 24, 2021 7:35 pm
by sna
Dear Norkaz
I mean that every subject come from student name is unique.(unique subject)
Like student name Mahi is subject to return is only English once time not three times.
Best Wishes
Re: index function
Posted: Mon May 24, 2021 8:13 pm
by norkaz
E2
=IFERROR(INDEX($B$1:$B$16,AGGREGATE(15,6,INDEX(ROW($B$1:$B$16)/(MATCH($D2&$B$1:$B$16,LOOKUP(ROW($A$1:$A$16),ROW($A$1:$A$16)/($A$1:$A$16<>""),$A$1:$A$16)&$B$1:$B$160,0)=ROW($A$1:$A$16)/($B$1:$B$16<>"")),0),COLUMNS($D$2:D2))),"")
Ctrl + Shift + Enter
Norkaz
Re: index function
Posted: Mon May 24, 2021 8:31 pm
by sna
Thank you it's working now
Re: index function
Posted: Tue May 25, 2021 9:11 am
by norkaz
sna wrote: Mon May 24, 2021 7:35 pm
Dear Norkaz
Best Wishes
Hi friend
A common problem.
Misunderstandings happen all the time, especially when communication is not clear. And can cost too much time.
One solution that works for many people is just only place the text sample (no need with the formula(s)) ,probably place 2-3 simply answers text values
" WITH THE COLOR HIGHLIGHT" in the template attached would be helpful.
This way might be able to help us save our time together and communicate clearly to find out the right solutions related to the Excel questions from the forum members -- and give you more helpful answer.
A sample as Excel attached.
I'd be happy to help.
Kind regards,
Norkaz
Re: index function
Posted: Tue May 25, 2021 9:43 am
by logic
norkaz wrote: Tue May 25, 2021 9:11 am
Strongly agree.
Re: index function
Posted: Fri May 28, 2021 6:00 am
by sna
Noted thanks
