Dim addme As Range, cNum As Integer
Dim x As Integer, y As Integer, Ck As Integer
Set addme = Sheet2.Cells(Rows.Count, 4).End(x1up).Offset(1, 0)
cNum = 7
Ck = 0
For x = 0 To Me.ListBox1.ListCount - 1
If Me.ListBox1.Selected(x) Then
Ck = 1
For y = 0 To cNum
addme.Offset(0, y) = Me.ListBox1.List(x, y)
Next y
Set addme = addme.Offset(1, 0)
ListBox1.Selected(x) = False
Next x
If Ck = 0 Then
MsgBox "There is nothing Selected"
Private Sub TextBox1_Change()
Dim i As Long
ListBox1.Clear
Me.ListBox1.AddItem
For x = 1 To 7
Me.ListBox1.List(0, x - 1) = Sheet1.Cells(1, x)
Next x
For i = 2 To Application.WorksheetFunction.CountA(Sheet1.Range("A:A"))
a = Len(Me.TextBox1.Text)
If StrConv(Left(Sheet1.Cells(i, 1).Value, a), vbLowerCase) = StrConv(Left(Me.TextBox1.Text, a), vbLowerCase) Then
Me.ListBox1.AddItem Sheet1.Cells(i, 1).Value
Me.ListBox1.List(ListBox1.ListCount - 1, 1) = Sheet1.Cells(i, 2).Value
Me.ListBox1.List(ListBox1.ListCount - 1, 2) = Sheet1.Cells(i, 3).Value
Me.ListBox1.List(ListBox1.ListCount - 1, 3) = Sheet1.Cells(i, 4).Value
Me.ListBox1.List(ListBox1.ListCount - 1, 4) = Sheet1.Cells(i, 5).Value
Me.ListBox1.List(ListBox1.ListCount - 1, 5) = Sheet1.Cells(i, 6).Value
Me.ListBox1.List(ListBox1.ListCount - 1, 6) = Sheet1.Cells(i, 7).Value
Private Sub TextBox2_Change()
Dim i As Long
ListBox1.Clear
Me.ListBox1.AddItem
For x = 1 To 7
Next x
a = Len(Me.TextBox2.Text)
If StrConv(Left(Sheet1.Cells(i, 2).Value, a), vbLowerCase) = StrConv(Left(Me.TextBox2.Text, a), vbLowerCase) Then
Private Sub TextBox3_Change()
Dim i As Long
ListBox1.Clear
Me.ListBox1.AddItem
For x = 1 To 7
Next x
a = Len(Me.TextBox3.Text)
If StrConv(Left(Sheet1.Cells(i, 3).Value, a), vbLowerCase) = StrConv(Left(Me.TextBox3.Text, a), vbLowerCase) Then
Private Sub TextBox4_Change()
Dim i As Long
ListBox1.Clear
Me.ListBox1.AddItem
For x = 1 To 7
Next x
a = Len(Me.TextBox4.Text)
If StrConv(Left(Sheet1.Cells(i, 4).Value, a), vbLowerCase) = StrConv(Left(Me.TextBox4.Text, a), vbLowerCase) Then
Private Sub TextBox5_Change()
Dim i As Long
ListBox1.Clear
Me.ListBox1.AddItem
For x = 1 To 7
Next x
a = Len(Me.TextBox5.Text)
If StrConv(Left(Sheet1.Cells(i, 5).Value, a), vbLowerCase) = StrConv(Left(Me.TextBox5.Text, a), vbLowerCase) Then
Private Sub TextBox6_Change()
Dim i As Long
ListBox1.Clear
Me.ListBox1.AddItem
For x = 1 To 7
Next x
a = Len(Me.TextBox6.Text)
If StrConv(Left(Sheet1.Cells(i, 6).Value, a), vbLowerCase) = StrConv(Left(Me.TextBox6.Text, a), vbLowerCase) Then
Private Sub TextBox7_Change()
Dim i As Long
ListBox1.Clear
Me.ListBox1.AddItem
For x = 1 To 7
Next x
a = Len(Me.TextBox7.Text)
If StrConv(Left(Sheet1.Cells(i, 7).Value, a), vbLowerCase) = StrConv(Left(Me.TextBox7.Text, a), vbLowerCase) Then
