สอบถามการแก้ไข Filter ครับ และ Export PDF แบบมีเงื่อนไข
Posted: Mon Apr 03, 2017 10:59 pm
Sub Button17_Sort2()
Dim stword1 As String
Dim stword2 As String
Dim stword3 As String
Dim stword4 As String
Dim stword5 As String
Dim stword6 As String
stword3 = Mid(Range("A1"), 7, 50)
stword = "รายงานต่อใบอนุญาต สาขา"
stword4 = "นายหน้า ประกันวินาศภัย"
stword5 = "ประเภทใบอนุญาต"
Range("B5") = stword & " " & stword3 & " " & stword5 & " " & stword4
Range("E3").Select
ActiveSheet.ListObjects("Table4").TableStyle = "TableStyleLight18"
ActiveSheet.ListObjects("Table4").Range.AutoFilter Field:=13, Criteria1:= _
"=นายหน้า", Operator:=xlOr, Criteria2:="=โบรคเกอร์"
ActiveWorkbook.Worksheets("Sort").ListObjects("Table4").Sort.SortFields.Clear
ActiveWorkbook.Worksheets("Sort").ListObjects("Table4").Sort.SortFields.Add _
Key:=Range("Table4[ครั้งที่]"), SortOn:=xlSortOnValues, Order:= _
xlAscending, DataOption:=xlSortTextAsNumbers
Key:=Range("Table4[วันหมดอายุ]"), SortOn:=xlSortOnValues, Order:= _
xlAscending, DataOption:=xlSortNormal
With ActiveWorkbook.Worksheets("Sort").ListObjects("Table4").Sort
.Header = xlYes
.MatchCase = False
.Orientation = xlTopToBottom
.SortMethod = xlPinYin
.Apply
Range("SortTable").Select
Selection.Rows.AutoFit
Columns("B:I").Columns.AutoFit
Columns("J:K").ColumnWidth = 13.88
Columns("L:L").EntireColumn.Hidden = True
Columns("M:M").Columns.AutoFit
Columns("N:N").ColumnWidth = 11
End SubCode: Select all
Sub Button28_PDF()
'www.contextures.com
'for Excel 2010 and later
Dim wsA As Worksheet
Dim wbA As Workbook
Dim strTime As String
Dim strName As String
Dim strPath As String
Dim strFile As String
Dim strPathFile As String
Dim myFile As Variant
Dim codebranch As String
Dim branchname As String
Dim lictype As String
On Error GoTo errHandler
lictype = Mid(Range("B5"), 48, 7)
codebranch = Left(Range("A1"), 3)
branchname = Mid(Range("A1"), 7, 50)
Set wbA = ActiveWorkbook
Set wsA = ActiveSheet
strTime = Format(Now(), "dd_mm_yy")
'get active workbook folder, if saved
strPath = wbA.Path
If strPath = "" Then
strPath = Application.DefaultFilePath
strPath = strPath & "\"
'replace spaces and periods in sheet name
strName = Replace(wsA.Name, " ", "")
strName = Replace(strName, ".", "_")
'create default name for savng file
strFile = lictype & "_" & codebranch & "_" & branchname & "_" & strTime & ".pdf"
strPathFile = strPath & strFile
'use can enter name and
' select folder for file
myFile = Application.GetSaveAsFilename _
(InitialFileName:=strPathFile, _
FileFilter:="PDF Files (*.pdf), *.pdf", _
Title:="Select Folder and FileName to save")
'export to PDF if a folder was selected
If myFile <> "False" Then
wsA.ExportAsFixedFormat _
Type:=xlTypePDF, _
Filename:=myFile, _
Quality:=xlQualityStandard, _
IncludeDocProperties:=True, _
IgnorePrintAreas:=False, _
OpenAfterPublish:=False
'confirmation message with file info
MsgBox "PDF file has been created: " _
& vbCrLf _
& myFile
exitHandler:
errHandler:
MsgBox "Could not create PDF file"
Resume exitHandler
