LineNotify ข้อความภาษาไทยเป็น ???? แต่ภาษาอังกฤษได้แก้ยังไงครับ
Posted: Sun Jan 08, 2023 8:21 pm
by chinnapong
ตามหัวข้อเลยครับ LineNotify ข้อความภาษาไทยเป็น ???? แต่ภาษาอังกฤษได้แก้ยังไงครับ
Excel version 2016
Sub LineNotifyUploadPic(msg As String, Optional UploadFilePath As String = "none")
Dim sFilepath As String
Dim nFile As Integer
Dim baBuffer() As Byte
Dim ssPostData1 As String Dim ssPostData2 As String Dim ssPostData3 As String Dim Messagelength As Integer Dim objectXML As Object
Dim arr1() As Byte Dim arr2() As Byte Dim arr3() As Byte Dim arr4() As Byte
Const STR_BOUNDARY As String = "xxx---thepexcel---thepexcel---thepexcel---xxx" '??? Token ??????
LineToken = "I2UXLTEOlMmiHPkTu7VFHmrORRUFt9COHLPKL4ZPYSy"
sFilepath = UploadFilePath
sFileName = GetFilenameFromPath(sFilepath)
ssPostData1 = vbCrLf & _
"--" & STR_BOUNDARY & vbCrLf & _
"Content-Disposition: form-data; name=" & """message""" & vbCrLf & vbCrLf & vbCrLf & Range("K1").Value
arr1 = StrConv(ssPostData1, vbFromUnicode) arr2 = (msg)
ssPostData2 = vbCrLf & _
"Content-Disposition: form-data; name=" & """imageFile""" & "; filename=" & sFileName & vbCrLf & _
"Content-Type: image/jpng" & vbCrLf & vbCrLf
arr3 = StrConv(ssPostData2, vbFromUnicode)
nFile = FreeFile
Open sFilepath For Binary Access Read As nFile If LOF(nFile) > 0 Then
ReDim baBuffer(0 To LOF(nFile) - 1) As Byte Get nFile, , baBuffer
imagear = baBuffer
Close nFile
 arr4 = StrConv(vbCrLf & "--" & STR_BOUNDARY & "--" & vbCrLf, vbFromUnicode)
Dim arraytotal As Long
Dim sendarray() As Byte
arraytotal = UBound(arr1) + UBound(arr2) + UBound(arr3) + UBound(imagear) + UBound(arr4) + 4
ReDim sendarray(arraytotal)
For i = 0 To UBound(arr1) sendarray(i) = arr1(i) Next
For i = 0 To UBound(arr2) sendarray(UBound(arr1) + i + 1) = arr2(i) Next
For i = 0 To UBound(arr3)
sendarray(UBound(arr1) + UBound(arr2) + i + 2) = arr3(i) Next
For i = 0 To UBound(imagear)
sendarray(UBound(arr1) + UBound(arr2) + UBound(arr3) + i + 3) = imagear(i) Next
For i = 0 To UBound(arr4)
sendarray(UBound(arr1) + UBound(arr2) + UBound(arr3) + UBound(imagear) + i + 4) = arr4(i)
Next
Set objectXML = CreateObject("Microsoft.XMLHTTP") URL = "https://notify-api.line.me/api/notify"
With objectXML
.Open "POST", URL, 0
.SetRequestHeader "Content-Type", "multipart/form-data; boundary=" & STR_BOUNDARY
.SetRequestHeader "Authorization", "Bearer " & LineToken .send sndar(sendarray)
Debug.Print .responseText
Set objectXML = Nothing
Public Function sndar(sendarray As Variant) As Byte()
sndar = sendarray
End Function
Public Function GetFilenameFromPath(ByVal strPath As String) As String If Right$(strPath, 1) <> "\" And Len(strPath) > 0 Then
 GetFilenameFromPath = GetFilenameFromPath(Left$(strPath, Len(strPath) - 1)) + Right$(strPath, 1)
End Function
Re: LineNotify ข้อความภาษาไทยเป็น ???? แต่ภาษาอังกฤษได้แก้ยังไงครับ
Posted: Sun Jan 08, 2023 9:39 pm
:D ลองทดสอบด้วย Code ด้านล่างว่าส่งภาษาไทย (คำว่า "สวัสดี") ได้หรือไม่ครับ
Sub Test0()
    Dim winReq As Object, iMsg As String
    Dim tk As String, postdata As String
    Set winReq = CreateObject("Microsoft.XMLHTTP")
    tk = "I2UXLTEOlMmiHPkTu7VFHmrORRUFt9COHLPKL4ZPYSy"
    myURL = "https://notify-api.line.me/api/notify"
    postdata = "message=" & "สวัสดี"
    With winReq
        .Open "POST", myURL, False
        .SetRequestHeader "Content-Type", "application/x-www-form-urlencoded"
        .SetRequestHeader "Authorization", "Bearer " & tk
        .send ("message=" & postdata)
Posted: Mon Jan 09, 2023 9:17 am
by chinnapong
snasui wrote: Sun Jan 08, 2023 9:39 pm :D ลองทดสอบด้วย Code ด้านล่างว่าส่งภาษาไทย (คำว่า "สวัสดี") ได้หรือไม่ครับ
Sub Test0()
    With winReq
Codeอันบนได้ครับแต่ผมส่งใส่น่าจะเป็นแถวนี้ครับ :flw:
Posted: Mon Jan 09, 2023 9:42 am
:D ลองปรับ Code ที่ผมตอบไปโดยใช้ค่าใน K1 แทนคำว่า "สวัสดี" แล้วทดสอบดูใหม่ครับ
