มีปัญหาเรื่อง Application.OnTime อัพเดทซ้อนกันครับ(แนบไฟล์มา
Posted: Sat May 11, 2013 8:38 pm
ชุมชนความรู้ Excel และ Microsoft 365 สำหรับการทำงานจริง ตั้งแต่สูตร ฟังก์ชัน VBA, Power Query, PivotTable, Dashboard และ AI จนถึงการวิเคราะห์ข้อมูลและพัฒนาระบบงานในองค์กร
https://snasui.com/
CommandButton2 เป็นตามด้านล่างครับ
CommandButton1.Enabled = True
continueTime = False
Application.OnTime nextTime, "update", , False
End SubCode: Select all
If ComboBox1.Text = "" Then Exit Sub
CommandButton1.Enabled = False
startTime = Now()
ActiveSheet.Range(Cells(1, 1), Cells(200, 1)).Clear
continueTime = True
row = 1
If ComboBox1.ListIndex = 0 Then
AddTime = TimeValue("0:00:01")
ElseIf ComboBox1.ListIndex = 1 Then
AddTime = TimeValue("0:00:02")
ElseIf ComboBox1.ListIndex = 2 Then
AddTime = TimeValue("0:00:03")
ElseIf ComboBox1.ListIndex = 3 Then
AddTime = TimeValue("0:00:04")
ElseIf ComboBox1.ListIndex = 4 Then
AddTime = TimeValue("0:00:05")
ElseIf ComboBox1.ListIndex = 5 Then
AddTime = TimeValue("0:00:06")
update0
Option Explicit
Public continueTime As Boolean
Public row As Long
Public nextTime As Date
Public startTime As Date
Public AddTime As Date
Sub update0()
If continueTime Then
nextTime = Now() + AddTime
ActiveSheet.Cells(row, 1).Select
Cells(row, 1).Value = Format$(Now() - startTime, "hh:nn:ss")
row = row + 1
Application.OnTime nextTime, "Update0"
Application.OnTime nextTime, "update0", , False
startTime = Now()
startTime1 = Now()
continueTime = True
row = 1
AddTime = TimeValue("00:00:01")
AddTime = TimeValue("00:00:02")
AddTime = TimeValue("00:00:03")
AddTime = TimeValue("00:00:04")
AddTime = TimeValue("00:00:05")
AddTime = TimeValue("00:00:06")
Update0
UpdateTime
Application.OnTime nextTime, "Update0", , False
Application.OnTime nextTime1, "UpdateTime", , False
Private Sub CommandButton3_Click()
Unload Me
Private Sub UserForm_Activate()
With UserForm1.ComboBox1
.AddItem "1 sec", 0
.AddItem "2 sec", 1
.AddItem "3 sec", 2
.AddItem "4 sec", 3
.AddItem "5 sec", 4
.AddItem "6 sec", 5
Option Explicit
Public row As Long
Public nextTime1 As Date
Public startTime1 As Date
Sub Update0()
row = row + 1
Sub UpdateTime()
nextTime1 = Now() + TimeValue("00:00:01")
UserForm1.TextBox1.Text = Format$(Now() - startTime1, "hh:nn:ss")
sheet PowerEx
id name description type value unit time staus
1 11CG gas 01 analog 0.153381591 MW 4/4/2014 20:16 Good
2 12CG gas 02 analog 0.823648765 MW 4/4/2014 20:17 Good
**คอลัม value ข้อมูลจะเเรมด้อม
sheet sheet1
A B
11CG 12CG
0.153381591 0.823648765
x 5 sec ผ่านไป y 5 sec ผ่านไป
ประมาณนี้ครับคือสามารถเพิ่มข้อมูลใน sheet Powerex ได้ตลอดเเล้วสามารถเก็บข้อมูลลจากsheet Powerex ลงใน sheet1 ได้ เเล้วทำตามรูปแบบตัวอย่างและสร้างกราฟเส้นดูค่าเปลี่ยนแปลงได้ใน sheet1 ได้ครับ
Option Explicit
Public row As Long, ws1 As Long, wsPx As Long
Public column As Long
Sub Update0()
Do Until Selection.Value = ""
Application.Calculate
ws1.Value = Worksheets("Sheet1").Cells(row + 1, 1).End(xlUp).Offset(1, 0).Select
wsPx.Value = Worksheets("PowerEx").Range("E" & Cells(row + 1, 5)).End(xlUp).Offset(1, 0).Select
ws1.Value = wsPx.Value
row = row + 1
Sub UpdateTime()
nextTime = Now() + TimeValue("00:00:01")
UserForm1.TextBox1.Text = Format$(Now() - startTime, "hh:nn:ss")
Application.OnTime nextTime, "UpdateTime"
Dim row1 As Long
Sub CopyAuto()
row1 = 1
Worksheets("PowerEx").Select
Range(Cells(row1, 2), Cells(row1, 2)).End(xlUp).Offset(1, 0).Select
Selection.Copy
Worksheets("Sheet1").Select
Range(Cells(row1, 2), Cells(row1, 2)).End(xlToRight).Offset(0, 1).Select
ActiveSheet.Paste
row1 = row1 + 1
Application.OnTime nextTime, "CopyAuto"
Private Sub CommandButton4_Click()
Worksheets("Sheet1").Range("A" & Cells(Rows.Count, 1).End(xlUp).row + 1).Select
ActiveSheet.Shapes.AddChart.Select
ActiveChart.SetSourceData Source:=Range("Sheet1!$A$1:$B$100")
ActiveChart.ChartType = xlLineMarkers
Selection.Copy
ActiveSheet.Paste
row1 = row1 + 1
Dim h As Boolean
Sub CopyAuto()
' กำหนดคัดลอกวางออโต้ชื่อของเส้น
If h = False Then
Range("b2", Range("b" & Rows.Count).End(xlUp)).Copy
Worksheets("Sheet1").Range("a1").PasteSpecial xlPasteValues, _
Transpose:=True
h = True
Range("e2", Range("e" & Rows.Count).End(xlUp)).Copy
Worksheets("Sheet1").Range("a" & Rows.Count).End(xlUp).Offset(1, 0) _
.PasteSpecial xlPasteValues, Transpose:=True
' row1 = 1 'row1 เก็บค่า1 ไว้
' Do Until Selection.Value = "" 'สั่งให้ทวนจนกว่าจะเจอช่องว่าง
' Range(Cells(row1, 2), Cells(row1, 2)).End(xlUp).Offset(1, 0).Select
' Selection.Copy
' Worksheets("Sheet1").Select
' Range(Cells(row1, 2), Cells(row1, 2)).End(xlToRight).Offset(0, 1).Select
' ActiveSheet.Paste
' row1 = row1 + 1
' Application.CutCopyMode = False
' Loop
Sub MarkGraph()
'สร้างกราฟ
ActiveChart.ChartType = xlLine ' เปลี่ยนกราฟเส้น
ActiveChart.SetSourceData Source:=Range("$A$1").Select
Selection.End(xlUp).Select
Selection.End(xlToLeft).Select
Range(Selection, Selection.End(xlToRight)).Select
' ActiveChart.ChartType = xlLine วางตรงนี้เเล้วเปลี่ยนการเป็นกราฟเส้นไม่ได้
Sub MarkGraph()
'สร้างกราฟ
With Sheets("Sheet1")
.Range("A1").CurrentRegion.Activate
With ActiveChart
.ChartType = xlLine
.SetSourceData Range("a1").CurrentRegion, PlotBy:=xlColumns
