Page 1 of 2
Import ข้อมูลจาก Excel มา Access
Posted: Mon Apr 03, 2023 4:09 pm
by Xcelvba
Form ชื่อ F-Q-EMP ครับ ปุ่ม Command 14 ขึ้น Error ครับ
Private Sub Command14_Click()
Dim fd As Object ' Late-bound FileDialog object
Dim strFilePath As String
Dim cnn As Object ' Late-bound ADODB connection object
Dim rs As Object ' Late-bound ADODB recordset object
Dim strSql As String
' Create a FileDialog object
Set fd = Application.FileDialog(3) ' msoFileDialogFilePicker
' Set the title and filters for the dialog box
With fd
.Title = "Select Excel File"
.Filters.Clear
.Filters.Add "Excel Files", "*.xlsx;*.xls"
' Show the dialog box and get the file path
If fd.Show = -1 Then
strFilePath = fd.SelectedItems(1)
' Open the Excel file using an ADODB connection
Set cnn = CreateObject("ADODB.Connection")
cnn.Open "Provider=Microsoft.ACE.OLEDB.12.0;Data Source=" & strFilePath & ";Extended Properties=""Excel 12.0 Xml;HDR=YES;"""
' Read the data from the Excel file into a recordset object
Set rs = CreateObject("ADODB.Recordset")
rs.Open "SELECT * FROM [Sheet1$]", cnn, adOpenStatic, adLockOptimistic
' Iterate through the recordset object and insert or update the data in the Access table as necessary.
Do While Not rs.EOF
strSql = "SELECT * FROM Tb_Employee WHERE [Employee ID]='" & rs("Employee ID").Value & "'"
If DCount("*", "Tb_Employee", strSql) > 0 Then
' Record already exists in Access, update the record
strSql = "UPDATE Tb_Employee SET [Pre_Name_TH]='" & rs("Pre_Name_TH").Value & "', [Firstname_TH]='" & rs("Firstname_TH").Value & "', [Lastname_TH]='" & rs("Lastname_TH").Value & "', [Pre_Name_EN]='" & rs("Pre_Name_EN").Value & "', [Firstname_EN]='" & rs("Firstname_EN").Value & "', [Lastname_EN]='" & rs("Lastname_EN").Value & "', [Date of Birth]=" & rs("Date of Birth").Value & ", [Gender]='" & rs("Gender").Value & "', [Nationality]='" & rs("Nationality").Value & "', [Contact Number]='" & rs("Contact Number").Value & "', [Department]='" & rs("Department").Value & "', [Position]='" & rs("Position").Value & "', [Address]='" & rs("Address").Value & "', [ZIP Code]='" & rs("ZIP Code").Value & "', [ID_card]='" & rs("ID_card").Value & "', [Image]=rs('Image').Value WHERE [Employee ID]='" & rs("Employee ID").Value & "'"
CurrentDb.Execute strSql
' Record does not exist in Access, insert a new record
strSql = "INSERT INTO Tb_Employee ([Employee ID], [Pre_Name_TH], [Firstname_TH], [Lastname_TH], [Pre_Name_EN], [Firstname_EN], [Lastname_EN], [Date of Birth], [Gender], [Nationality], [Contact Number], [Department], [Position], [Address], [ZIP Code], [ID_card], [Image]) VALUES ('" & rs("Employee ID").Value & "', '" & rs("Pre_Name_TH").Value & "', '" & rs("Firstname_TH").Value & "', '" & rs("Lastname_TH").Value & "', '" & rs("Pre_Name_EN").Value & "', '" & rs("Firstname_EN").Value & "', '" & rs("Lastname_EN").Value & "', #" & Format(rs("Date of Birth").Value, "yyyy\/mm\/dd") & "#, '" & rs("Gender").Value & "', '" & rs("Nationality").Value & "', '" & rs("Contact Number").Value & "', '" & rs("Department").Value & "', '" & rs("Position").Value & "', '" & rs("Address").Value & "', '" & rs("ZIP Code").Value & "', '" & rs("ID_card").Value & "', rs('Image').Value)"
Re: Import ข้อมูลจาก Excel มา Access
Posted: Mon Apr 03, 2023 4:26 pm
![Very Happy :D](./images/smilies/icon_e_biggrin.gif)
จาก Error กรุณาตรวจสอบว่าหลัง
Do
ใส่
ไว้ครบถ้วนแล้วหรือไม่ครับ
Posted: Mon Apr 03, 2023 4:50 pm
by Xcelvba
เจอแล้วครับพอ กด open file จาก browse แล้ว error บรรทัดนี้ครับ
Posted: Mon Apr 03, 2023 4:56 pm
จับภาพ Popup ที่แสดง Error มาด้วยครับ
Posted: Mon Apr 03, 2023 5:05 pm
by Xcelvba
snasui wrote: ↑Mon Apr 03, 2023 4:56 pm
ขอเพิ่มเติมรูปภาพครับ +ไฟล์ที่ import ครับ
Posted: Mon Apr 03, 2023 5:09 pm
แนบไฟล์ Access ล่าสุดที่ได้ปรับ Code มาแล้วด้วยจะได้ตอบต่อไปจากนั้นครับ
Posted: Tue Apr 04, 2023 8:07 am
by Xcelvba
snasui wrote: ↑Mon Apr 03, 2023 5:09 pm
ไฟล์ที่ปรับปรุงแล้วครับ
Posted: Tue Apr 04, 2023 8:23 am
ลองปรับ recordset โดยไม่ใช้ Parameter 2 ตัวท้ายครับ
จาก
rs.Open "SELECT * FROM [Sheet1$]", cnn , adOpenStatic, adLockOptimistic
ปรับเปํน
ส่วนของ Loop ใน Code ใส่ไว้ผิดตำแหน่ง กรุณาตรวจสอบและวางไว้ยังตำแหน่งที่ถูกต้องด้วยครับ
Posted: Tue Apr 04, 2023 9:06 am
by Xcelvba
เรียนอาจารย์ยัง error อยู่ครับ
Do While Not rs.EOF
Posted: Tue Apr 04, 2023 9:12 am
บรรทัดที่ Highlight กับ Popup Error
ไม่สอดคล้องกัน กรุณาตรวจสอบใหม่ว่า Error ที่บรรทัดไหนครับ
Posted: Tue Apr 04, 2023 9:25 am
by Xcelvba
บรรทัดที่ Highlight กับ Popup Error ไม่สอดคล้องกัน กรุณาตรวจสอบใหม่ว่า Error ที่บรรทัดไหนครับ
ผมลอง Import ไฟล์ Excel 123 เข้าไปใหม่อีกรอบนึง pop up เด้งขึ้นมาตามรูปภาพเลยครับ พอกด debug เด้งไปที่ตรงเส้นสีเหลืองครับ
Posted: Tue Apr 04, 2023 9:41 am
หากเป็นเช่นนั้นให้ตรวจสอบ 2 อย่างครับ
- Statement ที่เกิดใน Popup ได้ผลลัพธ์เป็นอะไร ซึ่งจะต้องเข้าใจ Statement ของ SQL และสามารถนำไปทดสอบเองได้ใน Access หากย้งไม่ทราบวิธีการ ควรศึกษามาก่อน
- Function Dcount มีส่วนประกอบอะไรบ้าง แต่ละส่วนประกอบมีความหมายว่าอย่างไร ข้อนี้สัมพันธ์กับข้อ 1 เพราะเป็นการนำข้อ 1 มาใช้เป็นส่วนประกอบของ Dcount และทำให้เกิด Popup เช่นนั้น
Posted: Tue Apr 04, 2023 10:22 am
by Xcelvba
Error เปลี่ยนแล้วครับ
Do While Not rs.EOF
If DCount("*", "Tb_Employee", strSq) > 0 Then
Posted: Tue Apr 04, 2023 10:52 am
ทำการ Debug Statement นี้ครับ
โดย Debug ไปทีละค่าว่าค่าที่นำมาเชื่อมกันนั้นให้ผลลัพธ์เป็นอะไรบ้าง ยกตัวอย่างเช่น
ให้ค่าเป็นอะไร
ให้ค่าเป็นอะไร
ฯลฯ
การใช้ VBA ต้อง Debug โดยวิธีการติดตามตัวแปรเองให้เป็นหรืออย่างน้อยสามารถคีย์สอบถามใน Immediate Windows ได้ครับ
วิธีการคร่าว ๆ
- เปิดหน้าต่าง Immediate Windows จากเมนู View
- คีย์เพื่อตรวจสอบผลลัพธ์ของสิ่งที่สนใจเช่น
? strSql
- สังเกตผลลัพธ์ที่ได้
Posted: Tue Apr 04, 2023 1:37 pm
by Xcelvba
ผมลอง Debug แล้วครับ ได้ค่าดังนี้
[Pre_Name_TH]=Null
[Firstname_TH]='·´Òͺºº'
[Lastname_TH]='Åͧ'
[Pre_Name_EN]=Null
[Firstname_EN]=Null
[Lastname_EN]=Null
[Date of Birth]=13/4/2566
[Gender]='ªÒÂ'
[Nationality]='ä·Â'
[Contact Number]='081-1111111'
[Department]='·´Êͺ¢éÍÁÙÅ'
[Position]=Null
[Address]=Null
[ZIP Code]='50210'
[ID_card]=''
[Image]=rs('Image').Value WHERE [Employee ID]='10000'
ผมเจอบรรทัดนี้ แปลก ผมเลยปรับโค้ด เป็น
strSql = "UPDATE Tb_Employee SET [Pre_Name_TH]='" & rs("Pre_Name_TH").Value & "', [Firstname_TH]='" & rs("Firstname_TH").Value & "', [Lastname_TH]='" & rs("Lastname_TH").Value & "', [Pre_Name_EN]='" & rs("Pre_Name_EN").Value & "', [Firstname_EN]='" & rs("Firstname_EN").Value & "', [Lastname_EN]='" & rs("Lastname_EN").Value & "', [Date of Birth]=" & rs("Date of Birth").Value & ", [Gender]='" & rs("Gender").Value & "', [Nationality]='" & rs("Nationality").Value & "', [Contact Number]='" & rs("Contact Number").Value & "', [Department]='" & rs("Department").Value & "', [Position]='" & rs("Position").Value & "', [Address]='" & rs("Address").Value & "', [ZIP Code]='" & rs("ZIP Code").Value & "', [ID_card]='" & rs("ID_card").Value & "', [Image]= '" & rs("Image").Value & "' WHERE [Employee ID]='" & rs("Employee ID").Value & "'"
แต่ก็ยัง ERROR และ pop up เช่นเดิมครับอาจารย์
Posted: Tue Apr 04, 2023 2:35 pm
หลังจากปรับ Code แล้ว ตัวแปร
strSql
ได้เป็นค่าใดครับ
![Question :?:](./images/smilies/icon_question.gif)
Posted: Tue Apr 04, 2023 4:28 pm
by Xcelvba
[Pre_Name_TH]='',
[Firstname_TH]='·´Òͺºº',
[Lastname_TH]='Åͧ',
[Pre_Name_EN]='',
[Firstname_EN]='',
[Lastname_EN]='',
[Date of Birth]=13/4/2566,
[Gender]='ªÒÂ',
[Nationality]='ä·Â',
[Contact Number]='081-1111111',
[Department]='·´Êͺ¢éÍÁÙÅ',
[Position]='',
[Address]='',
[ZIP Code]='50210',
[ID_card]='',
[Image]= ''
ได้เป็นค่านี้ครับ
Posted: Tue Apr 04, 2023 4:41 pm
ดูแล้วสามารถรันได้ ลองทดสอบเอา Statement นี้ไปรันใน Query ของ Access (ซึ่งจะต้องเข้ามุมมอง SQL) เพื่อดูว่าได้ผลเป็นเช่นไรครับ
หากรันไม่ผ่านแสดงว่า Statement นี้มีปัญหา ให้แจ้งปัญหานั้นมาอีกรอบครับ
้สังเกตว่า
วันที่ไม่ได้ครอบด้วย
ในการรัน Query หากไม่ผ่านอาจทดสอบด้วยการครอบด้วย
ดูอีกรอบว่าผ่านหรือไม่
Posted: Wed Apr 05, 2023 8:53 am
by Xcelvba
snasui wrote: ↑Tue Apr 04, 2023 4:41 pm
้สังเกตว่า
ลองแก้วันที่แล้วครับ Error ตลอดครับ แต่ถ้านำ CurrentDb.Execute strSql ออกจะเด้ง pop-up ดังรูปครับ ส่วนโค็ดที่ทดสอบคือ
UPDATE Tb_Employee SET [Pre_Name_TH]='" & rs("Pre_Name_TH").Value & "', [Firstname_TH]='" & rs("Firstname_TH").Value & "', [Lastname_TH]='" & rs("Lastname_TH").Value & "', [Pre_Name_EN]='" & rs("Pre_Name_EN").Value & "', [Firstname_EN]='" & rs("Firstname_EN").Value & "', [Lastname_EN]='" & rs("Lastname_EN").Value & "', [Date of Birth]='" & rs("Date of Birth").Value & "', [Gender]='" & rs("Gender").Value & "', [Nationality]='" & rs("Nationality").Value & "', [Contact Number]='" & rs("Contact Number").Value & "', [Department]='" & rs("Department").Value & "', [Position]='" & rs("Position").Value & "', [Address]='" & rs("Address").Value & "', [ZIP Code]='" & rs("ZIP Code").Value & "', [ID_card]='" & rs("ID_card").Value & "', [Image]= '" & rs("Image").Value & "' WHERE [Employee ID]='" & rs("Employee ID").Value & "'
Posted: Wed Apr 05, 2023 9:14 am
ต้องเอา Statement ที่ได้จากตัวแปร
strSql
ไปทดสอบ
ไม่ใช่นำ Statement ของ VBA ไปใช้โดยตรงครับ
