Sub Insertrow()
Dim r As Range, rAll As Range
Dim rHeader As Range
Dim rInsert As Range
With Sheets("Sheet2")
Set rAll = .Range("I6", .Range("I" & Rows.Count).End(xlUp))
Set rHeader = .Range("A5:I5")
For Each r In rAll
If r & r.Offset(0, -1) <> r.Offset(1, 0) & r.Offset(1, -1) _
And r.Offset(1, 0) <> "" Then
r.Offset(1, 1) = True
Set rInsert = .Range("J:J").SpecialCells(xlCellTypeConstants)
For Each r In rInsert
r.Resize(4, 1).EntireRow.Insert shift:=xlShiftDown
r.Offset(-2, -9) = r.Offset(0, -2) & " " & "(" & r.Offset(0, -1) & ")"
r.Offset(-1, -9).Resize(1, 9) = rHeader.Value
ActiveCell.HorizontalAlignment = xlLeft
ActiveCell.Font.Bold = True
.Range("J:J").Clear
Sub InsertRow()
Dim j As Integer
For Each r In rAll
j = .Range("J:J").SpecialCells(xlCellTypeConstants).Count
For i = 1 To j
Set r = .Range("J" & Rows.Count).End(xlUp)
r.ClearContents
' Call AllFormatCell
Call CreateFormat
Sub CreateFormat()
Dim rAll As Range
Dim r As Range
Set rAll = .Range("I:I").SpecialCells(xlCellTypeConstants)
For Each r In rAll
r.Offset(0, -8).Resize(1, 9).Borders.LineStyle = xlContinuous
