ต้องการ search key word ให้ให้แสดงค่า refference code
Posted: Tue Jan 21, 2014 3:12 pm
+ต้องการ search key word ให้ให้แสดงค่า refference code+
1. ต้องการ search key word ใน column A (tab sheet ""search")
2.โดยให้ key word เข้าไป search ใน column B (tab sheet ""Source Data")
3.B2 ต้องการให้คื่นค่า refference code (tab sheet ""search")
Key word Value
10A4216X012 =MATCH(A2,'Source Data'!B:B,0)
10A4218X022 #N/A
10A4220X012 #N/A
15A6634X042 #N/A
15A6654X012 #N/A
RGASKETX362 #N/A
V111349X012 #N/A
V111385X012 #N/A
Reff Code Free Text len
592391.930.3 Instruments,FISHER,Description: PIPE PLUG,Part Number: 1A767524662,Material: ,Range: ,Sizing: 32
592393.248.3 Instruments,FISHER,Description: STEM,Part Number: 10A8823XA22,Material: ,Range: ,Sizing: 27
592392.830.3 Instruments,FISHER,Description: SEAT RING,Part Number: 20B3515N012,Material: ,Range: ,Sizing: 32
592392.930.3 Instruments,FISHER,Description: VALVE SHAFT,Part Number: 21B6851X012,Material: ,Range: ,Sizing: 32
592391.474.3 Instruments,FISHER,Description: DISC,Part Number: 28A4748N032,Material: ,Range: ,Sizing: 27
592391.376.3 Instruments,FISHER,Description: BUSHING,Part Number: K15628K0012,Material: ,Range: ,Sizing: 30
592391.254.3 Instruments,FISHER,Description: BACK UP RING,Part Number: 1V6596X0032,Material: ETHYLENE-PROPYLENE,Range: ,Sizing: 35
592391.246.3 Instruments,FISHER,Description: BACK UP RING,Part Number: 1V6592X0032,Material: ETHYLENE-PROPYLENE,Range: ,Sizing: 35
592391.944.3 Instruments,FISHER,Description: PISTON RING,Part Number: 1U2342X0012,Material: ,Range: ,Sizing: 34
592392.850.3 Instruments,FISHER,Description: SEAT RING,Part Number: 22B6022X012,Material: ,Range: ,Sizing: 32
592392.260.3 Instruments,FISHER,Description: PLUG,Part Number: 16A5328X012,Material: ,Range: ,Sizing: 27
592391.502.3 Instruments,FISHER,Description: GASKET,Part Number: 12B7100X012,Material: ,Range: ,Sizing: 35
592392.448.3 Instruments,FISHER,Description: PLUG & STEM SEAT,Part Number: 17A9233X022,Material: ,Range: ,Sizing: TRIM 1",PORT 1/2",STEM 1/2" 34
592391.222.3 Instruments,FISHER,Description: BACK UP RING,Part Number: 10A4218X022,Material: 416 STAINLESS STEEL,Range: ,Sizing: 35
592392.594.3 Instruments,FISHER,Description: SEAL RING,Part Number: 10A4216X012,Material: ,Range: ,Sizing: 32
592392.554.3 Instruments,FISHER,Description: RETAINING RING,Part Number: 10A4220X012,Material: ,Range: ,Sizing: 37
592391.832.3 Instruments,FISHER,Description: O-RING,Part Number: V111385X012,Material: FLUOROELASTOMER,Range: ,Sizing: 29
592391.914.3 Instruments,FISHER,Description: PACKING SET,Part Number: V111699X012,Material: ,Range: ,Sizing: 34
592392.648.3 Instruments,FISHER,Description: SEAL RING,Part Number: V111349X012,Material: ,Range: ,Sizing: 32
592391.674.3 Instruments,FISHER,Description: GASKET,Part Number: V124603X022,Material: ,Range: ,Sizing: 27
4.ไม่ทราบว่าต้องใช้สูตรอะไร ผมลองใช้ '=MATCH(A2,'Source Data'!B:B,0)
5. ยังขึ้น error รบกวนผู้รู้แนะนำด้วยครับ
Key word Value
10A4218X022 #N/A
10A4220X012 #N/A
15A6634X042 #N/A
15A6654X012 #N/A
RGASKETX362 #N/A
V111349X012 #N/A
V111385X012 #N/A
