ต้องการให้เวลา Save เป็น PDF ให้แสดงหน้า 2 ก่อนหน้า 1
Posted: Thu May 02, 2024 8:47 am
เรียน อาจารย์
ต้องปรับ Code อย่างไรครับ ขอบคุณครับ
Sub Button1_Click()
Worksheets("Forms").Activate
'www.contextures.com
'for Excel 2010 and later
Dim wsA As Worksheet
Dim wbA As Workbook
Dim strTime As String
Dim strName As String
Dim strPath As String
Dim strFile As String
Dim strPathFile As String
Dim myFile As Variant
On Error GoTo errHandler
Set wbA = ActiveWorkbook
Set wsA = ActiveSheet
strTime = Format(Now(), "yyyymmdd\_hhmm")
'get active workbook folder, if saved
strPath = wbA.Path
If strPath = "" Then
strPath = Application.DefaultFilePath
strPath = strPath & "\"
'replace spaces and periods in sheet name
strName = Replace(wsA.Name, " ", "")
strName = Replace(strName, ".", "_")
'create default name for savng file
strFile = Sheets("Input").Range("RefNo").Value & ".pdf"
strPathFile = strPath & strFile
'use can enter name and
' select folder for file
myFile = Application.GetSaveAsFilename _
(InitialFileName:=strPathFile, _
FileFilter:="PDF Files (*.pdf), *.pdf", _
Title:="Select Folder and FileName to save")
'export to PDF if a folder was selected
If myFile <> "False" Then
wsA.ExportAsFixedFormat _
Type:=xlTypePDF, _
Filename:=myFile, _
Quality:=xlQualityStandard, _
IncludeDocProperties:=True, _
IgnorePrintAreas:=False, _
OpenAfterPublish:=False
'confirmation message with file info
MsgBox "PDF file has been created: " _
& vbCrLf _
& myFile
exitHandler:
errHandler:
MsgBox "Could not create PDF file"
Resume exitHandler
