Return repeat customer
Posted: Mon Aug 12, 2024 12:22 am
by sna
Hi there,
I need your help how to write formula to extract only repeat customers with date
I attach a template and expected outputs in color cells.
Thx
Note i need both dynamic array and excel 2019
Re: Return repeat customer
Posted: Mon Aug 12, 2024 9:18 am
by norkaz
Need helper columns to avoid the complicated formulas.
H2
=IFERROR(SEARCH(";",SUBSTITUTE($B2,CHAR(160),""),G2+1),999)
Copy a formula to the right and down.
P2
=IFERROR(";"&MID(SUBSTITUTE($B2,CHAR(160),""),G2+1,H2-G2-1),"")
Y2
=IF(SUMPRODUCT(1/COUNTIF(P2:W2,P2:W2))-1=COUNTA(P2:W2)-
COUNTBLANK(P2:W2),"",ROW(Y2))
Copy down a column
AA2
=IFERROR(INDEX($P2:$W2,AGGREGATE(15,6,{1,2,3,4,5,6,7,8}/(MATCH($P2:$W2,$P2:$W2,0)<>{1,2,3,4,5,6,7,8}),COLUMNS($AA2:AA2))),"")
AG2
=MID(AA2&AB2&AC2&AD2&AE2&AF2,2,99)
Copy down a column
Output
E2
=IFERROR(INDEX(C:C,SMALL($Y$2:$Y$11,ROWS(E$2:E2))),"")
Copy down a column
F2 =IFERROR(INDEX(AG:AG,SMALL($Y$2:$Y$11,ROWS(F$2:F2))),"")
Copy down a column
Excel365
** Still need a helper column to avoid the complicated Spill Array formula
Helper
H2
=CONCAT(SORT(IF(LET(t,TEXTSPLIT(SUBSTITUTE(B2,CHAR(160),""),";"),IFERROR(IF(SEARCH(";",B2),IF(XMATCH(t,t)={1,2,3,4,5,6,7,8},"",t),""),""))="","",";"&LET(t,TEXTSPLIT(SUBSTITUTE(B2,CHAR(160),""),";"),IFERROR(IF(SEARCH(";",B2),IF(XMATCH(t,t)={1,2,3,4,5,6,7,8},"",t),""),""))),,-1,1))
Copy down a column
Output
E2
=IFERROR(HSTACK(INDEX(C:C,SORT(ROW(H2:H7)/(H2:H7<>""))),MID(INDEX(H:H,SORT(ROW(H2:H7)/(H2:H7<>""))),2,99)),"")
Bigcat9Excel
Bangkok Thailand
Posted: Mon Aug 12, 2024 9:45 am
by sna
thanks,it's always nice
Posted: Mon Aug 12, 2024 9:46 am
by sna
is it possible without helper column even excel 365?
Posted: Mon Aug 12, 2024 8:20 pm
You can use this formula in Excel 365.
E2
=LET(a,MAP(B2:B7,LAMBDA(a,TEXTJOIN("; ",TRUE,FILTERXML("<t><s>"&SUBSTITUTE(SUBSTITUTE(a,CHAR(160),""),";","</s><s>")&"</s></t>","//s[preceding::*=.]")))),FILTER(HSTACK(C2:C7,a),ISTEXT(a)))
Posted: Mon Aug 12, 2024 9:36 pm
by sna
Thanks ,always be helpful
