vba
Posted: Thu Sep 12, 2024 1:15 pm
by sna
Dear All,
I need a simplified vba code to copy some values from Sheet"Date" to Sheet "Paster"
if Cell B1 is 1 so i need to copy data from Sheet "Date" of below data under of 1 in sheet "Date" to Sheet"Paster"
I attach a template
I have no luck
Noted: Dynamic array formula is allowed
Thx
Re: vba
Posted: Fri Sep 13, 2024 6:09 am
The example of code is below.
'Othe code
' Loop through each row in the Date sheet and copy rows based on the value in column A
For i = 2 To lastRowDate
' If wsDate.Cells(i, 1).Value = cellValue Then
wsDate.Rows(i).Copy Destination:=wsPaster.Rows(destRow)
destRow = destRow + 1
' End If
Re: vba
Posted: Fri Sep 13, 2024 8:27 am
by sna
I mean to copy only when cell value is 1 equals to column a in sheet "Date" 1 SoSambath 13-09-2024
A Input Office OutSide Authorize Amount
- Transaction 30 - 74 -
- BookingLoan/Reschedule 1 - 1 -
- BookingMCMM/ReEV 1 - - -
- CheckCIF(Credit/FSR) 9 - - -
- PDArrear 7 - 4 -
- RunPayroll 7 - - -
- TaxCar/Payment 1 - - -
- AM(Form50-147) - - 1 -
- ChangeInfomationCIF/ACC - - 1 -
- VMS - - 13 -
B CrossService - - - -
- ReferralPrudential - - - -
- ReferralLoan - - - -
- OtherService - - - -
C Total: 56 - 94 -
D Subtotal: 150 - - -
Re: vba
Posted: Fri Sep 13, 2024 7:43 pm
Please try this code.
Sub Test0()
Dim fOne As Range, fStt As Range
Dim lstC As Range, srRngs As Range
If Not IsNumeric(Worksheets("Paster").Range("B1")) Then
MsgBox "The value in A1 is not a valid number.", vbExclamation
With Worksheets("Date")
Set lstC = .Range("b" & .Rows.Count).End(xlUp)
Set fOne = .Range("a:a").Find(what:=1, LookIn:=xlValues, lookat:=xlPart)
Set fStt = .Range(fOne, lstC).Find(what:="Subtotal:", LookIn:=xlValues, lookat:=xlPart)
Set srRngs = .Range(fOne, fStt).Resize(, 6)
With Worksheets("Paster")
.Range("b1").CurrentRegion.Offset(1, 0).ClearContents
.Range("b2").Resize(srRngs.Rows.Count, srRngs.Columns.Count).Value = srRngs.Value
Re: vba
Posted: Fri Sep 13, 2024 11:01 pm
by sna
Thanks so much
Re: vba
Posted: Mon Sep 23, 2024 5:17 pm
by sna
Hi Dear,
I need to copy all data meet criteria in cell B1 in Sheet Paster .
I attach a template
thx
Re: vba
Posted: Tue Sep 24, 2024 6:25 am
The example code is below.
Sub Test1()
Dim ws As Worksheet
Dim firstAddress As String
Dim cell As Range, sv As String
Dim cpRngs As Range
Set ws = ThisWorkbook.Sheets("Date")
Set wt = ThisWorkbook.Sheets("Paster")
With wt
sv = wt.Range("b1").Value
.UsedRange.Offset(1, 0).ClearContents
Set cell = ws.Columns("B").Find(What:=sv, LookIn:=xlValues, LookAt:=xlWhole)
If Not cell Is Nothing Then
firstAddress = cell.Address
Do
With ws
Set cpRngs = .Range(cell, cell.End(xlDown))
With wt
cpRngs.Resize(, 6).Copy .Range("b" & .Rows.Count).End(xlUp).Offset(1, 0)
Set cell = ws.Columns("B").FindNext(cell)
Loop While Not cell Is Nothing And cell.Address <> firstAddress
Re: vba
Posted: Wed Sep 25, 2024 10:17 am
by sna
Thanks ,really helpful
