ขออนุญาตสอบถามเรื่องปัญหา code การค้นหาและปฏิทิน
Posted: Thu Sep 23, 2021 10:19 am
by 9KiTTi
ขออนุญาตอ้างถึง
https://snasui.com/viewtopic.php?f=3&t=18301
ของสมาชิกครับ
ผมได้นำมาปรับเพิ่มเติมในฟอร์มการค้นหา แต่ติดปัญหาไม่สามารถใช้งานได้
Option Explicit
Dim FormEvents As Boolean
Private Sub ClearForm(Except As String)
    Select Case Except
        Case "ReceiveNO"
            FormEvents = False
            BookNO.value = ""
            DateIN.value = ""
            From.value = ""
            Too.value = ""
            Detail.value = ""
            Results.Clear
            FormEvents = True
        Case "BookNO"
            FormEvents = False
            ReceiveNO.value = ""
            DateIN.value = ""
            From.value = ""
            Too.value = ""
            Detail.value = ""
            Results.Clear
            FormEvents = True
        Case "DateIN"
            FormEvents = False
            BookNO.value = ""
            From.value = ""
            Too.value = ""
            Detail.value = ""
            Results.Clear
            FormEvents = True
        Case "From"
            FormEvents = False
            BookNO.value = ""
            DateIN.value = ""
            Too.value = ""
            Detail.value = ""
            Results.Clear
            FormEvents = True
        Case "Too"
            FormEvents = False
            BookNO.value = ""
            DateIN.value = ""
            From.value = ""
            Detail.value = ""
            Results.Clear
            FormEvents = True
        Case "Detail"
            FormEvents = False
            BookNO.value = ""
            DateIN.value = ""
            From.value = ""
            Too.value = ""
            Results.Clear
            FormEvents = True
        Case Else
            FormEvents = False
            BookNO.value = ""
            DateIN.value = ""
            From.value = ""
            Too.value = ""
            Detail.value = ""
            Results.Clear
            FormEvents = True
        End Select
Private Sub BasicCalendar_Click()
    dateVariable = CalendarForm.GetDate
    If dateVariable <> 0 Then SearchForm.DateIN.Text = Format(dateVariable, "d mmm yyyy")
Private Sub ClearBtn_Click()
    ClearForm ("")
Private Sub CloseBtn_Click()
    Me.Hide
Private Sub ReceiveNO_Change()
    If FormEvents Then ClearForm ("ReceiveNO")
Private Sub BookNO_Change()
    If FormEvents Then ClearForm ("BookNO")
Private Sub DateIN_Change()
    If FormEvents Then ClearForm ("DateIN")
Private Sub From_Change()
    If FormEvents Then ClearForm ("From")
Private Sub Too_Change()
    If FormEvents Then ClearForm ("Too")
Private Sub Detail_Change()
    If FormEvents Then ClearForm ("Detail")
Private Sub SearchBtn_Click()
    Dim SearchTerm As String
    Dim SearchColumn As String
    Dim RecordRange As Range
    Dim FirstAddress As String
    Dim FirstCell As Range
    Dim RowCount As Integer
    If ReceiveNO.value = "" And BookNO.value = "" And DateIN.value = "" And From.value = "" And Too.value = "" And Detail.value = "" Then
        MsgBox "No search term specified", vbCritical + vbOKOnly
    If ReceiveNO.value <> "" Then
        SearchTerm = ReceiveNO.value
        SearchColumn = "เลขทะเบียนรับ"
    If BookNO.value <> "" Then
        SearchTerm = BookNO.value
        SearchColumn = "ที่"
    If DateIN.value <> "" Then
        SearchTerm = DateIN.value
        SearchColumn = "ลงวันที่"
    If From.value <> "" Then
        SearchTerm = From.value
        SearchColumn = "จาก"
    If Too.value <> "" Then
        SearchTerm = Too.value
        SearchColumn = "ถึง"
    If Detail.value <> "" Then
        SearchTerm = Detail.value
        SearchColumn = "เรื่อง"
    Results.Clear
        With Range("data[" & SearchColumn & "]")
            Set RecordRange = .Find(SearchTerm, LookIn:=xlValues)
            If Not RecordRange Is Nothing Then
                FirstAddress = RecordRange.Address
                RowCount = 0
                Do
                    Set FirstCell = Range("B" & RecordRange.Row)
                    Results.AddItem
                    Results.List(RowCount, 0) = FirstCell(1, 1)
                    Results.List(RowCount, 1) = FirstCell(1, 2)
                    Results.List(RowCount, 2) = FirstCell(1, 3)
                    Results.List(RowCount, 3) = FirstCell(1, 4)
                    Results.List(RowCount, 4) = FirstCell(1, 5)
                    Results.List(RowCount, 5) = FirstCell(1, 6)
                    RowCount = RowCount + 1
                    Set RecordRange = .FindNext(RecordRange)
                    If RecordRange Is Nothing Then
                Loop While RecordRange.Address <> FirstAddress
                Results.AddItem
                Results.List(RowCount, 0) = "ไม่พบข้อมูลที่ต้องการ!!!"
    FormEvents = True
แต่เกิด error ตามภาพครับ
อีกปัญหาคือผมทำฟังก์ชั่นปฏิทินในฟอร์มค้นหา แต่ไม่สามารถใช้งานได้ แต่ทำในฟอร์มหลักสามารถใช้งานได้ รบกวนแนะนำการปัญหาด้วยครับ
Code ของปฏิทินครับ
ขอบพระคุณครับ
Re: ขออนุญาตสอบถามเรื่องปัญหา code การค้นหาและปฏิทิน
Posted: Thu Sep 23, 2021 8:08 pm
by 9KiTTi
ตอนนี้ผมสามารถแก้ไขเรื่องปฏิทินได้แล้วครับ แต่พอกด seaarch แล้ว ไม่สามารถค้นหาข้อมูลได้ครับ รบกวนแนะนำผมด้วยครับ
ขอบพระคุณครับ
Posted: Fri Sep 24, 2021 7:31 am
:D กรุณาแนบไฟล์ล่าสุดมาด้วยจะได้ตอบต่อไปจากนั้นครับ
Posted: Fri Sep 24, 2021 6:03 pm
by 9KiTTi
ไฟล์ล่าสุดครับ
Posted: Sat Sep 25, 2021 7:56 am
9KiTTi wrote: Thu Sep 23, 2021 8:08 pm ตอนนี้ผมสามารถแก้ไขเรื่องปฏิทินได้แล้วครับ แต่พอกด seaarch แล้ว ไม่สามารถค้นหาข้อมูลได้ครับ รบกวนแนะนำผมด้วยครับ
ขอบพระคุณครับ
:D กรุณาอธิบายเรื่องการ Search มาอย่างละเอียดว่าปุ่ม Search อยู่ใน Form ไหน ค่าทดสอบคือค่าใด ผลลัพธ์ที่ถูกต้องควรมีค่าใด จะได้เข้าถึงปัญหาโดยเร็วครับ
Posted: Sat Sep 25, 2021 9:57 pm
by 9KiTTi
ปุ่ม search จะอยู่ในหน้าหนังสือทะเบียนรับ อยู่ใน frame รายละเอียดหนังสือ เลือกหมวดรายการค้นหาจาก "ค้นหาจาก" โดยใส่คำในช่อง "สิ่งที่ต้องการค้นหา" แล้วกด Search ครับ ถ้าจากพบข้อมูลในแสดงรายละเอียดใน listbox ข้างล่างครับ แต่หลังจากกดแล้วขึ้น ขึ้น rum-time error 1004 ครับ
vba ที่มใช้กับปุ่ม search ตามนี้ครับ
Sub SearchData()
    Dim shDatabase As Worksheet ' Database sheet
    Dim shSearchData As Worksheet 'SearchData sheet
    Dim iColumn As Integer 'To hold the selected column number in Database sheet
    Dim iDatabaseRow As Long 'To store the last non-blank row number available in Database sheet
    Dim iSearchRow As Long 'To hold the last non-blank row number available in SearachData sheet
    Dim sColumn As String 'To store the column selection
    Dim sValue As String 'To hold the search text value
    Set shDatabase = ThisWorkbook.Sheets("Database")
    Set shSearchData = ThisWorkbook.Sheets("SearchData")
    iDatabaseRow = ThisWorkbook.Sheets("Database").Range("A" & Application.Rows.Count).End(xlUp).Row
    sColumn = frmForm.cmbSearchColumn.value
    sValue = frmForm.txtSearch.value
    iColumn = Application.WorksheetFunction.Match(sColumn, shDatabase.Range("A1:K1"), 0)
    'Remove filter from Database worksheet
    If shDatabase.FilterMode = True Then
       shDatabase.AutoFilterMode = False
    'Apply filter on Database worksheet
    If frmForm.cmbSearchColumn.value = "เลขทะเบียนรับ" Then
        shDatabase.Range("A1:K" & iDatabaseRow).AutoFilter Field:=iColumn, Criteria1:=sValue
        shDatabase.Range("A1:K" & iDatabaseRow).AutoFilter Field:=iColumn, Criteria1:="*" & sValue & "*"
    If Application.WorksheetFunction.Subtotal(3, shDatabase.Range("C:C")) >= 2 Then
        'Code to remove the previous data from SearchData worksheet
        shSearchData.Cells.Clear
        shDatabase.AutoFilter.Range.Copy shSearchData.Range("A1")
        iSearchRow = shSearchData.Range("A" & Application.Rows.Count).End(xlUp).Row
        frmForm.lstDatabase.ColumnCount = 12
        frmForm.lstDatabase.ColumnWidths = "40,70,75,75,75,80,70,70,70,350,70,70"
        If iSearchRow > 1 Then
            frmForm.lstDatabase.RowSource = "SearchData!A2:K" & iSearchRow
            MsgBox "ไม่พบข้อมูลที่ค้นหา"
       MsgBox "No record found."
ขอวิธีแก้ไขด้วยครับ ขอบพระคุณครับ
Posted: Sun Sep 26, 2021 6:53 am
:D กำหนดของเขต Table ใหม่ตามภาพครับ
Posted: Sun Sep 26, 2021 11:01 am
by 9KiTTi
snasui wrote: Sun Sep 26, 2021 6:53 am :D กำหนดของเขต Table ใหม่ตามภาพครับ
ผมลองปรับอย่างที่อาจารย์แนะนำแล้วครับ แต่สามารถค้นหาได้แค่ตัวเลือกตัวเดียวครับ และค้นหาจากตัวเลือกได้แค่แถวที่1 กับ 2 ครับ ส่วนตัวเลือกอื่นค้นหาไม่ได้ครับ
Posted: Sun Sep 26, 2021 12:30 pm
:D ควร Debug Code ด้วยตนเองแล้วแจ้งมาว่าบรรทัดไหนไม่ทำงาน หรือทำงานไม่ตรงกับที่ต้องการครับ
การใช้ Code จำเป็นต้อง Debug ให้เป็นไม่เช่นนั้นจะทำงานกับ VBA ได้อย่างลำบาก วิธีการ Debug Code ดูเบี้องต้นได้ตาม Link นี้ครับ https://snasui.com/viewtopic.php?f=3&t= ... 47#p103247
Code ที่เขียนควรทำให้คอลัมน์การค้นหาผันแปรไปตาม Item ที่เลือกใน ComboBox ไม่เช่นนั้นย่อมนำค่าต้นทางไปค้นได้ไม่ตรงกับคอลัมน์ปลายทาง
ก่อนการค้นหาทุกครั้งจะต้องยกเลิกการ Filter (ถ้ามี) ทิ้งเสียก่อน ตัวอย่าง Code บางส่วนตามด้านล่างครับ
    shDatabase.ShowAllData
If Application.WorksheetFunction.Subtotal(3, shDatabase.Columns(iColumn)) >= 2 Then
    shDatabase.UsedRange.Copy shSearchData.Range("A1")
Posted: Tue Oct 19, 2021 1:42 pm
by 9KiTTi
snasui wrote: Sun Sep 26, 2021 12:30 pm :D ควร Debug Code ด้วยตนเองแล้วแจ้งมาว่าบรรทัดไหนไม่ทำงาน หรือทำงานไม่ตรงกับที่ต้องการครับ
การใช้ Code จำเป็นต้อง Debug ให้เป็นไม่เช่นนั้นจะทำงานกับ VBA ได้อย่างลำบาก วิธีการ Debug Code ดูเบี้องต้นได้ตาม Link นี้ครับ viewtopic.php?f=3&t=17483&p=103247#p103247
ขออภัยอาจารย์ครับ ผมพึ่งได้ทดสอบ พึ่งมีเวลาว่างจากเรื่องโควิดครับ ผมได้ลองไฟล์ที่อาจารย์ตอบมาให้ พบว่าหลังจากที่กดค้นหาแล้ว สามารถค้นหาได้เพียงครั้งแรก หลังจากนั้นพอ Debug อย่างที่อาจารย์แล้วพบปัญหาตามภาพที่แนบมาครับ และหลังจากเปิดดู Sheet database พบว่าคอลัมม์ยังมี Filter ที่คอมลลัม์แม้จะเขียน code เพื่อปิดการทำงานแล้วครับ
รบกวนอาจารย์แนะนำด้วยครับ ขอบพระคุณครับ
Posted: Tue Oct 19, 2021 6:40 pm
:D กรุณาแนบไฟล์ล่าสุดมาด้วยครับ
Posted: Tue Oct 19, 2021 8:03 pm
by 9KiTTi
snasui wrote: Tue Oct 19, 2021 6:40 pm :D กรุณาแนบไฟล์ล่าสุดมาด้วยครับ
ขออภัยครับอาจารย์ ผมลืมครับ
Posted: Tue Oct 19, 2021 8:26 pm
:D ลองปรับ Code เป็นด้านล่างครับ
If shDatabase.FilterMode Then
    'shDatabase.ShowAllData
    shDatabase.ListObjects("Table2").AutoFilter.ShowAllData
ทั้งนี้เนื่องจากมีการใช้ Table แทน Range ธรรมดา อย่าลืมแก้ส่วนอื่นเช่นการแสดงข้อมูลบน Message Box ให้แสดงข้อมูลที่สอดคล้องกับที่เป็นจริงด้วยครับ
Posted: Wed Oct 20, 2021 1:07 pm
by 9KiTTi
snasui wrote: Tue Oct 19, 2021 8:26 pm :D ลองปรับ Code เป็นด้านล่างครับ
ใช้งานได้แล้วครับ รวมทั้งแก้ไข Message Box ตามที่อาจารย์แนะนำด้วยครับ เหลือทำในส่วนหนังสือส่ง ขอบพระคุณครับอาจารย์
