vba
Posted: Thu Sep 12, 2024 1:15 pm
by sna
Dear All,
I need a simplified vba code to copy some values from Sheet"Date" to Sheet "Paster"
if Cell B1 is 1 so i need to copy data from Sheet "Date" of below data under of 1 in sheet "Date" to Sheet"Paster"
I attach a template
I have no luck
Noted: Dynamic array formula is allowed
Thx
Re: vba
Posted: Fri Sep 13, 2024 6:09 am
:D The example of code is below.
'Othe code
    ' Loop through each row in the Date sheet and copy rows based on the value in column A
    For i = 2 To lastRowDate
'        If wsDate.Cells(i, 1).Value = cellValue Then
            wsDate.Rows(i).Copy Destination:=wsPaster.Rows(destRow)
            destRow = destRow + 1
'        End If
Re: vba
Posted: Fri Sep 13, 2024 8:27 am
by sna
I mean to copy only when cell value is 1 equals to column a in sheet "Date" 1 SoSambath 13-09-2024
A Input Office OutSide Authorize Amount
- Transaction 30 - 74 -
- BookingLoan/Reschedule 1 - 1 -
- BookingMCMM/ReEV 1 - - -
- CheckCIF(Credit/FSR) 9 - - -
- PDArrear 7 - 4 -
- RunPayroll 7 - - -
- TaxCar/Payment 1 - - -
- AM(Form50-147) - - 1 -
- ChangeInfomationCIF/ACC - - 1 -
- VMS - - 13 -
B CrossService - - - -
- ReferralPrudential - - - -
- ReferralLoan - - - -
- OtherService - - - -
C Total: 56 - 94 -
D Subtotal: 150 - - -
Re: vba
Posted: Fri Sep 13, 2024 7:43 pm
:D Please try this code.
Sub Test0()
    Dim fOne As Range, fStt As Range
    Dim lstC As Range, srRngs As Range
    If Not IsNumeric(Worksheets("Paster").Range("B1")) Then
        MsgBox "The value in A1 is not a valid number.", vbExclamation
    With Worksheets("Date")
        Set lstC = .Range("b" & .Rows.Count).End(xlUp)
        Set fOne = .Range("a:a").Find(what:=1, LookIn:=xlValues, lookat:=xlPart)
        Set fStt = .Range(fOne, lstC).Find(what:="Subtotal:", LookIn:=xlValues, lookat:=xlPart)
        Set srRngs = .Range(fOne, fStt).Resize(, 6)
    With Worksheets("Paster")
        .Range("b1").CurrentRegion.Offset(1, 0).ClearContents
        .Range("b2").Resize(srRngs.Rows.Count, srRngs.Columns.Count).Value = srRngs.Value
Re: vba
Posted: Fri Sep 13, 2024 11:01 pm
by sna
Thanks so much 🙏
Re: vba
Posted: Mon Sep 23, 2024 5:17 pm
by sna
Hi Dear,
I need to copy all data meet criteria in cell B1 in Sheet Paster .
I attach a template
thx
Re: vba
Posted: Tue Sep 24, 2024 6:25 am
:D The example code is below.
Sub Test1()
    Dim ws As Worksheet
    Dim firstAddress As String
    Dim cell As Range, sv As String
    Dim cpRngs As Range
    Set ws = ThisWorkbook.Sheets("Date")
    Set wt = ThisWorkbook.Sheets("Paster")
    With wt
        sv = wt.Range("b1").Value
        .UsedRange.Offset(1, 0).ClearContents
    Set cell = ws.Columns("B").Find(What:=sv, LookIn:=xlValues, LookAt:=xlWhole)
    If Not cell Is Nothing Then
        firstAddress = cell.Address
        Do
            With ws
                Set cpRngs = .Range(cell, cell.End(xlDown))
            With wt
                cpRngs.Resize(, 6).Copy .Range("b" & .Rows.Count).End(xlUp).Offset(1, 0)
            Set cell = ws.Columns("B").FindNext(cell)
        Loop While Not cell Is Nothing And cell.Address <> firstAddress
Re: vba
Posted: Wed Sep 25, 2024 10:17 am
by sna
Thanks ,really helpful
