Re: สอบถามครับ การกำหนดค่าหลายตัวแปร
Posted: Sat Aug 18, 2018 1:08 pm
ได้แล้วครับขอบพระคุณมากครับ
ชุมชนความรู้ Excel และ Microsoft 365 สำหรับการทำงานจริง ตั้งแต่สูตร ฟังก์ชัน VBA, Power Query, PivotTable, Dashboard และ AI จนถึงการวิเคราะห์ข้อมูลและพัฒนาระบบงานในองค์กร
http://snasui.com/
Private Sub TextBox5_AfterUpdate()
With Workbooks("DataX.xlsx").Worksheets("Sheet1")
Set rngVlp = .Range("a2", .Range("d" & .Rows.Count).End(xlUp))
With ThisWorkbook.Worksheets("IN")
emptyrow = .Range("a" & .Rows.Count).End(xlUp).Offset(1, 0).Row
If Me.TextBox5.Text = "10021" Then
Worksheets("IN").Cells(emptyrow - 1, 1).EntireRow.Delete
Me.TextBox11.Text = Application.WorksheetFunction.Sum(Range("H3:H1048576"))
If MsgBox("Do you want to delete the data? ", vbYesNo + vbQuestion + vbDefaultButton2, " Close and Save ") = 6 Then
If Me.TextBox5.Text = "" Then Exit Sub
If WorksheetFunction.CountIfs(Workbooks("DataX.xlsx").Worksheets("Sheet1").Range("A:A"), Me.TextBox5.Value, _
Workbooks("DataX.xlsx").Worksheets("Sheet1").Range("E:E"), Me.TextBox2.Value) = 0 Then
Call Sample2
'Me.TextBox5.Value = ""
MsgBox "Please Check Information"
Me.TextBox6.Text = Application.VLookup(CDbl(Me.TextBox5.Text), rngVlp, 2, 0)
Me.TextBox7.Text = Application.VLookup(CDbl(Me.TextBox5.Text), rngVlp, 3, 0)
Me.TextBox8.Text = Application.VLookup(CDbl(Me.TextBox5.Text), rngVlp, 4, 0)
With Worksheets("IN")
.Cells(emptyrow, 1).Value = TextBox1.Value
.Cells(emptyrow, 2).Value = TextBox2.Value
.Cells(emptyrow, 3).Value = ComboBox1.Value
.Cells(emptyrow, 4).Value = TextBox5.Value
.Cells(emptyrow, 5).Value = TextBox6.Value
.Cells(emptyrow, 6).Value = TextBox7.Value
.Cells(emptyrow, 7).Value = TextBox8.Value
.Cells(emptyrow, 8).Value = TextBox9.Value
Dim total As Long
total = WorksheetFunction.Sum(Range("H3:H1048576"))
Range("A1").Value = total
Range("C1") = TextBox10.Value
If Range("A1").Value > Range("C1") Then
Call Sample2
MsgBox "TOTAL NUMBER ERROR"
Dim lsRow As Long
With Sheets("IN")
lsRow = .Range("a" & .Rows.Count).End(xlUp).Row
ListBox1.RowSource = Sheets("IN").Range("A3:H" & lsRow).Address(external:=True)
With ListBox1
.ListIndex = .ListCount - 1
.Selected(.ListCount - 1) = True
Private Sub TextBox5_Exit(ByVal Cancel As MSForms.ReturnBoolean)
If TextBox5.Value <> "" Then
Cancel = True
TextBox5.Text = ""
Leng wrote: Mon Sep 03, 2018 11:18 am โดยบาร์โค๊ด
8 0601 68019 00 1 ต้อง มี 2 ตัว
8 0601 71019 00 5 ต้อง มี 2 ตัว
8 0601 69019 00 0 ต้อง มี 2 ตัว
8 0601 67019 00 2 ต้อง มี 2 ตัว
8 0601 70019 00 6 ต้อง มี 2 ตัว
Dim total As Long
Call Sample2
Dim rngCmpr As Range
Dim rngBrcd As Range
Set rngvlp = .Range("a2", .Range("d" & .Rows.Count).End(xlUp))
Set rngBrcd = rngvlp.Resize(, 1)
Set rngCmpr = .Range("g2", .Range("g" & .Rows.Count).End(xlUp))
With Application
If .CountIf(rngCmpr, Me.TextBox5.Text) > 0 And _
.CountIf(rngBrcd, Me.TextBox5.Text) > 2 Then
MsgBox "<Your message>", vbInformation
Leng wrote: Tue Sep 04, 2018 8:44 am ไฟล์ Test ถ้าหาก Barcode ใน Cloum A ในไฟล์ Datax ตรงกับ Box ใน Cloum E ถึงจะ scan ได้
.CountIf(rngBrcd, Me.TextBox5.Text) > 2 ThenrngCmpr เป็นจำนวนมากกว่า 0 ค่า และพบค่าใน TextBox5 ในพื้นที่ rngBrcd จำนวนมากกว่า 2 ค่าแล้วให้แสดงคำสั่งเดือนrngCmpr ส่วนตัวแปร rngBrcd คือข้อมูล Barcode ในคอลัมน์ A ของไฟล์ DataX.xlsx กรณีข้อมูลเปลี่ยนแปลงไปจากที่เคยส่งมาถามจะต้องปรับค่าตัวแปรใน Code ให้ตรงกับตำแหน่งข้อมูลจริง ในเครื่องผมสามารถตรวจสอบข้อมูลได้ตามปกติและหากไม่ตรงกับเงื่อนไขที่ต้องการ ให้อธิบายมาใหม่ให้ละเอียดLeng wrote: Mon Sep 03, 2018 11:18 am กล่องเบอร์ 1 มี 10 ตัว (โดยการดึงข้มูลจาก DataX)
โดยบาร์โค๊ด
หากบาร์โค๊ดไหนเกินข้อมูลที่กำหนดไว้ ให้มีการแจ้งเตือนครับ
Set rngCmpr = .Range("f2", .Range("f" & .Rows.Count).End(xlUp))
With Application
If .CountIf(rngCmpr, Me.TextBox5.Text) < 0 And _
.CountIf(rngBrcd, Me.TextBox5.Text) < 2 Then
