Sub RangeNunFormat()
Dim r As Range, sh As Worksheet
Dim rAll As Range, i As Integer
For Each sh In Worksheets
If sh.Name <> "ตัวชี้วัด" Then
Set rAll = sh.Range("B6:B25")
For Each r In rAll
i = Application.VLookup(r, Worksheets("ตัวชี้วัด").Range("B5:D24"), 3, 0)
If i > 0 Then
r.Offset(0, 4).Resize(, 16).NumberFormat = "#,##0." & String(i, "0")
r.Offset(0, 4).Resize(, 16).NumberFormat = "#,##0"
Next sh
เรียนท่านอาจารย์ครับ ตาม code If sh.Name <> "ตัวชี้วัด" Then Set rAll = sh.Range("B6:B25")
For Each r In rAll
i = Application.VLookup(r, Worksheets("ตัวชี้วัด´").Range("B5:D24"), 3, 0)
If i > 0 Then
Sub RangeNumFormat()
Select Case Val(sh.Name)
Case 1 To 13
For Each r In rAll
If i > 0 Then
End Select
Next sh
